difference between meter range before and after launching.pdf (148.7 KB)
Hi Paul,
Thank you very much for your advice on the meter’s overall low bound and overall high bound in Ignition Designer.
I have removed the bindings from the above-mentioned engineering limits and it is working as expected.
You have bindings on the various properties of the component; those bindings will not be automatically re-evaluated within the designer (unless you close and re-open the window). Remove the bindings and the component will keep the values you specified in the designer.
Those bindings are automatically created when you drag a tag in from the tag browser to create a component; it uses internal tag properties such as the engineering limits to define the values on components such as the meter.
