Different value shown in Chrome and Edge
On one popup page, we display a value after dividing it by 10.
It displays correctly in Chrome, but not in Edge. For example, the actual value is 40 in Chrome shows 4 but in Edge 40
in Edge show 40
Please advise on how to resolve this issue.
    try:
        if value is None or value == "":
            return "0.0"
        return "{:.1f}".format(float(value))
    except:
        return "0.0"
Did you try removing the browser cache, then closing and reopening the browser again?
Or perhaps double check the URL?
i just chagne the format to none and now it show 4.0 on both browser.
Is that script transform of the text prop of an input component? If so the user won’t be able to edit the value. You need to use a bidirectional binding which is only available on tag and property bindings.
Additionally, for something that simple, you shouldn't be using a script transform, use an expression binding instead. Script transforms have a lot of overhead compared to other types. (but again, you shouldnt be using an expression or script at all for an input component's display binding)
