Hello!
We have come across a very weird issue in Ignition.
When using Numeric Entry Field to display a value like "35.67" it looks fine in the Edge browser. However when our customer has looked at it in Chrome it has been displayed as "3567", so the decimal point appears to be missing.
The value is a float from the tag and is displayed as "35.67754857", format has only changed it to 2 decimal points.
I have managed to fix it by changing to text field and formatting in expression of value.
I have not done further research and don't have any screenshots, sorry.
Is this a known issue? Has anyone else had the same problem?
Some locales have , for the thousands separator and a . for the decimal separator. Some have the exact opposite with a . for the thousands separator and a , for the decimal separator. Without seeing your code, it's hard to say; but perhaps you're passing what you think is formatted as a float, but the system is interpreting it as a whole number because of locale differences?
Forgot to answer but this was the issue. The values locales weren't hard formatted in the fields so it was interpreted by client. And as I and the customer had different languages in the browser it showed up differently.
