Dini Argeo Weighing Scale to Ignition
Can i get info about connecting Dini Argeo Weighing Scale to Ignition without using PLC?
Because the scale can connect direct to the Computer (PC) thru LAN or Bluetooth connection.
Is there a way to get the data directly to the ignition?
Please see reference:
DFWL
You’ll need to be more specific in which model you are using.
Yes sir,
We have 2 different scale that we used,
  1. DIGI SM-100
    Reference: https://www.digisystem.com/products/PRD00275/specification/
  2. DINI ARGEO DFWL-1 BTH
    Reference: http://www.diniargeo.com/lst/scales/weight-indicators/dfw-series.aspx
Please see reference for details.
Thank you.
In that case you can connect it to ignition server thru a socket module . Do you have the documentation or sdk for the lan connection to the device?
We use weigh console program to get data from the scale.
