Is there a way to connect Ignition to a Wago 750-363 or similar via Ethernet I/P?
I’d like to use a direct Ethernet I/P connection in this case, not one of the workarounds (e.g. using Modbus TCP instead or the new generation Wagos with MQTT/onboard OPC servers, buying a completely different PLC, etc).
@Kevin.Herron Thank you! A prompt no is the next best thing.
@pturmel is your driver at full release? Looking for something reliable / relatively straightforward that isn’t too much harder to add new tags than the built in Rockwell drivers as I’ll have electricians wanting to add tags from time to time. The fallback option is Modbus TCP but then I’ll need to map tags every time.
Lead times for many PLC brands are getting ludicrous here in New Zealand.
It's been in production release since October 2017. (I had to go look.)
Not sure what you mean. I/O connections are totally different from processor tag-based connections. Though the data brought in is presented as if tags in a processor. Some effort must be expended creating structured types or assemblies that match the byte-for-byte layout of the I/O buffers of the target device.
You can make most edits without stopping the device.
Let me know what actual models you will be using and get me the EDS files. I'm happy to help customers deploy this module.
Note that scanning I/O is a Premium feature of the module. The base version makes Ignition an I/O adapter.
I just read the application note for the 750-363 with an L32 processor. A bit more complicated than typical devices, but no surprises. I expect it to work.
Hi there, did you ever get this to work? looking at doing something similar, with using a Wago Ethernet module with IO modules attached and then connecting directly to ignition
Hey mate, we were in a huge rush and in the end I went indirectly via a ControlLogix.
Your only option for this specific application without a workaround or alternative architecture is @pturmel's driver.
I needed to match the number of bytes in and out with the number/size of IO modules on the fieldbus coupler. From memory, any error in either manifested as a "Wrong number of output bytes" (or similar) error, even if the mistake was in the number of input bytes. We also had to set a couple of options in the coupler's web portal, I think including setting the clock (?).
Teething problems aside, it worked pretty well.
Phil's driver does more or less the same thing, but brings the data into Ignition.
I assume you are integrating a bunch of old Wagos into a more modern system like I was?
