here is my scenario:
I have two PLC machines, machine#1 has a CycleOvertime bit that I want to send it to the Ignition gateway, then the gateway would let machine #2 know about this condition and give an indicator output.
Thanks in advance.
Thanks in advance.
You can accomplish that in one of three ways:
Create a DB expression tag with an expression that returns PLC 1’s tag value and writes it to PLC 2’s tag
Create a standard transaction group to do the same as 1.
Use a gateway tag change script to write from one PLC to another.
The first option will probably be the easiest.
lol, Travis, i have more than one option! I cant even figure one out.
I created a new DBtag , MyDBTag, with this expression
{[.]Ack_bit}={[~]PLC1/CycleOvertime_bit}
What did I do wrong here?
A single equals in the expression language is just equality not assignment. Look to the bottom of the expression tab and you will see a write-back section. There you can select the tag you want to write the above expression to.
I already tried the write back method like you suggested even before I tried that equal expression.
Anyway, just talked to Bob in support, I need to upgrade mine from v7.3 to v7.3.1 to get it work.
However creating a standard transaction group method does work on v7.3
