Disable button according to tag value
Is there an easy way to enable/ disable buttons according to a tag value?
In my case if a CIP process is on (So this tag value is 1) I want certain buttons to be disabled until this process is done and the tag value is 0 again.
I know there is an enable checkbox with true or false values but if i link my tag directly to this it only works in one way and i need the logic to be the other way around and can’t figure that out.
Use an expression binding with a boolean not (the exclamation point) and your tag reference. Something like this:
!{[myTagProvider]some/path/to/a/tag}
Thank you so much! I know it’s something little but if you don’t know it you can look for it for quite a while! haha
Can we disable a button after acknowledging particular alert in alarm status table and it should enable for alarms which are not acknowledged
