My application is connecting with modbus devices who are often offline. This makes my gateway logs look very cluttered. I can disable logs for modbus in the logging settings. But if the gateway restarts, the logging is back enabled. Is there a way to permanently disable error logging for modbus?
In the logback.xml file in the data directory, add a line like this:
<logger name="<full name of logger>" level="ERROR"/>
Hello, I tried to at this line at the end:
This broke all logging. Do i need to add this line at a specific place? I also tried before the tag.
It worked. The line has to be inserted right after the configuration opening tag
I also completely forgot it existed, but the easier option would be to use system.util.setLoggingLevel in a gateway startup script
