Disable print/save right click menu on Report Viewer
Hello all. Does anyone know a way to disable the right click print/save menu available on the Report Viewer? Alternatively is there a way to have it only show for specific roles?
If it is of any use I’m using version 7.5.5
Thanks for your time and any help.
There’s no way to disable the right-click in the Report, but you could put another component (like a label with no text) on top of the report that just has “pass” in the mouse pressed and mouse released events. If you do that, then you can set the visible property of the label based on the current user’s roles.
I have done what Robert.McKenzie suggested and it works.
