Disable scroll wheel increment and decrement on numeric entry field component
When the mouse is over the component and it is focused the scroll wheel changes the value. Does anybody know a way to disable this feature?
scroll
I've been down this road many times and found that the only way to accomplish this was by adding JavaScript :confused:
If you add a domId to your component and then add a markdown component and add:
<img style='display:none' src='/favicon.ico' onload="
        const numberInputs = document.querySelectorAll('#your_domId');
        numberInputs.forEach(function(input) {
            input.addEventListener('wheel', function(event) {
                event.preventDefault();
to the source it should work!
Glad this could be solved. A couple of follow up questions:
-I'm not clear on how to add a markdown component. Is this a matter of adding a "source" property to props like so:
-Does the domId have the # symbol before it or in this case would the domId be NumericEntry.
You can find the Markdown component under the "Display" section of the Perspective Components panel in the designer:
The Markdown component has a source property by default and that is where you put the javascript code that @jbexten posted above:
Lastly, The domId that you put on the numeric entry component goes in the Meta properties and it should not have a #:
