Good morning
Does anyone have a method to disable updating a table from sql?
I’m looking for something like the switch labelled “Live Values” on the Ignition Gateway -> Status-> Logs page
Good morning
You could always use the following setup (written from a Perspective point-of-view, but it can be accomplished in Vision as well):
if ToggleSwitch.props.selected:
Table.props.data = View.custom.query_value
Using this setup will populate your table with the data from the query until you “un-select” the ToggleSwitch or checkbox, at which point the Table will retain whatever data it already had. Toggling the switch will then re-activate the display of live data.
Sorry, this solution exist too for version 7.x?
