Hi all,
Is possible disable the error messages showed how popup in a Vision Client ( for example like that)
[attachment=0]errore.PNG[/attachment]
Thank you very much
Andrea
Hi all,
Thank you very much
Andrea
In bindings, no.
In scripts, you can use standard python “try … except …” clauses to intercept any errors and process them any way you like.
Whoops, forgot about the try() expression function for bindings. To use it for a SQL query, you’d have to move the query into an expression.
Hi
Is not only for the queries, but for everything. ( picture is only an example of the message error)
I would like to disable this message box at runtime.
Andrea
[quote=“andrea.minu”]I would like to disable this message box at runtime.[/quote]I don’t think you can. And really, anything failing at runtime that might show this dialog needs to be investigated and understood if you want a reliable system.
