Disabled button but it still working
I need to disable the buttons, but when this property is on it just changes the background color and the button still works. Do you know what the problem may be?
I am using version 7.9.8
Do you have your script in the button action or button mouse pressed?
Enabled only affects the onClicked actionPerformed action, the other mouse event handlers will still run, as @jpark alluded to. Either move your script to the onClicked actionPerformed event, or add a condition that checks the enabled property first
Are you sure it blocks onClicked? I thought enabled/disabled only affected actionPerformed.
:flushed: whoops, yep that was my bad!
