Disabling Text Selection and Image Dragging in Perspective Using CSS (Advanced Stylesheet)
I've been working on preventing accidental text selection and native image dragging in Perspective for customers who use Ignition Perspective as HMI, particularly when interacting with buttons, read-only texts, images, and embedded views.
I wanted to disable these behaviors across the application without interfering with normal component interactions, especially input fields and buttons.
I also added an exception for cases where text selection is actually needed. Setting a component's Meta → DOM ID to something starting with drag-allowed (e.g., drag-allowed-texts) excludes that element and its descendants from the global restrictions.
One thing I wanted to avoid was applying pointer-events: none directly to Perspective components, since that could interfere with their normal behavior. Instead, I limited it to the internal image and SVG elements.
Just sharing what I've come up with in case anyone else has been dealing with the same issue.
Perspective - Prevent Text Selection / Native Dragging
Default:
- Disable text selection and native browser dragging
- Include Embedded Views, Containers, and One-Shot Buttons
Exceptions:
- Input fields and editable content
- Elements with a domId starting with "drag-allowed"
  and all their descendants
Pointer Events:
- Disable only internal img / canvas / svg in Image components
- Disable decorative img / svg inside Buttons
- Keep pointer-events unchanged on components themselves
/* Disable text selection and native dragging globally */
#app-container,
#app-container *:not(
    [id^="drag-allowed"],
    [id^="drag-allowed"] *,
    input,
    textarea,
    [contenteditable=""],
    [contenteditable=""] *,
    [contenteditable="true"],
    [contenteditable="true"] *,
    [contenteditable="plaintext-only"],
    [contenteditable="plaintext-only"] *
    -webkit-user-select: none !important;
    -webkit-user-drag: none !important;
/* Allow text selection in editable and excluded areas */
#app-container :is(
    input,
    textarea,
    -webkit-user-select: text !important;
/* Image components: preserve existing pointer behavior */
#app-container
[data-component="ia.display.image"]
:is(img, canvas, svg):not(
    pointer-events: none;
/* Decorative images inside regular and One-Shot Buttons */
#app-container
:is(
    [data-component="ia.input.button"],
    [data-component="ia.input.oneshotbutton"]
:is(img, svg):not(
