Hello,
I’m having troubles with all the charts in a certain gateway (Ignition 7.9.14), while other plants with the same underling project (or slightly different ones) work fine.
When I disable the last pen in the chart, or when I enable it it throws this error:
Exception in thread "AWT-EventQueue-2" java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
at java.util.ArrayList.rangeCheck(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
at com.inductiveautomation.ignition.common.AbstractDataset.getColumnType(AbstractDataset.java:98)
at com.inductiveautomation.factorypmi.application.components.chart.easychart.PenData.setData(PenData.java:94)
at com.inductiveautomation.factorypmi.application.components.chart.easychart.TagHistoryPenDatasource.setData(TagHistoryPenDatasource.java:100)
at com.inductiveautomation.factorypmi.application.components.chart.easychart.AbstractChartQuery.handleQueryReturnedValue(AbstractChartQuery.java:146)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$HandleReturnValueTask.run(QueryManager.java:477)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
When I check (or uncheck) any other pen nothing strange happens.
I can’t figure out what to observe/test to identify the scope of the problem. Any help would be appreciated
