Hello,
We are monitoring OPC tags using the OPC quick client and also using the Designer tag browser. The tag originates from an outstation device using DNP3 and we use the DNP3 driver to connect it to the OPC UA server. When the outstation DNP3 point updates quickly (less than a second), the OPC tag in quick client also updates but the OPC tag in the Designer tag browser does not. Is there any difference between these two tags? Is there any reason why one might update and not the other?
Thanks in advance,
Andrei
