I would like to display my uptime unit which is a percent sign (%) but on the LED display I only se a backslash.
Is there a work around?
thanks
thanks
In the property editor, go to Appearance and then Style and select 5x7 Matrix. This should give you a more accurate percent. You may have to change your other LED Displays for a more uniform look. Not sure if this is what your looking for.
LED displays are limited in appearance. You have the mode like Greg said but it is difficult to display characters like that. You should use the Numeric Text Field instead.
