Hello,
I'm wondering if there's a way to show my alarms' custom subjects as a column in alarm status table ideally or in a regular table
Hello,
As in the custom email subject?
If so, it doesn't look like you can add it to the AST as a column. You could show it in another label when you select an alarm if that will suffice?
You could also create a custom prop on the alarm and copy the same value to it, and then you could show that using the columnsAssociated prop in the AST
Yes the email subject
You can put the subject in the label column of the alarm status table, and if need be, the label column's name can be changed.
Example:
Customizing Alarm Status Table
