Display blob image from database
I have been looking over code in these forums to load an image from the mysql database and have not had much success, I am using version 7.9.2
can anyone share code to display this in a paintable canvas, label, or image component?
here is my query:
presentation = event.source.parent.getComponent('Dropdown').selectedLabel
rowSlide = event.source.parent.currentSlidePath
image = system.db.runScalarPrepQuery("SELECT photo FROM presentations where presentation=? and series_name = ?", [presentation, rowSlide])
I did this also, check this thread here:
for the code I used and the solution provided to me to get it to work correctly.
Thanks abishur,
I saw your post and tried that earlier with no luck. I keep getting some errors.
File “event:propertyChange”, line 18, in
AttributeError: ‘NoneType’ object has no attribute ‘width’
Can you post the code you’ve done as a reference?
Edit:
The problem was that I did not save the blob correctly in the database. The label code is good though.
