Display issues on high DPI screens
On my laptop I have a large resolution so the DPI is set higher to make everything legible. I noticed there are some small issues with the splash screens and the FactorySQL Service Service Status screen you get when double-clicking the FSQL tray icon. Since all the text is bigger, but the box stays the same size, some of the information goes off to the side and is hidden. I attached screenshots in case I’m not being clear enough
I haven’t seen any issues with the FSQL configuration client. Everything seems to be the correct size and nothing is pushed off the sides of a window I can’t resize.
Is there any way to fix this besides setting my screen to a lower dpi?
Yeah, this is a known issue with high dpi screens. Our recommendation has always been to reduce the DPI back to normal.
Regards,
