I'm quering the UTC time from a named query and showing it on label component.
I have this binding on the label coponent but, it does not convert it into the local time.
Am I doing something wrong?
Rather than a format transform, have you tried using an expression transform with the getTimezoneOffset() expression?
You would need to turn the {value} into a date first though. I think you could use fromMillis()?
Okay, I understand why there is a 30 min offset. getTimezoneOffset() return value 5.5 in this case and addHours() rounds it up to 6.
But I can't figure out the right way to do this.
Why? Why not use an expression binding of now()?
My goal is to find the best method to display a timestamp from DB in local timezone in label component. Not really to display the current time.
This was just an example that I tried to use to show the situation.
Change your expression to addMinutes({value}, getTimezoneOffset({value}) * 60)
But why? Are you trying to check the DB server clock is correct? It seems strange.
Ewwww! Kevin!
That will break around DST changes.
Also:
The getTimezoneOffset function is DST aware. There’s a raw version that isn’t.
Right, but it can be a different value before and after the arithmetic. That the arithmetic yields a java.util.Date with the wrong underlying UTC instant is just begging for later trouble.
I’m not trying to do anything like that. I’m describing a case where timestamps are stored in UTC in the database, but need to be displayed in the local time zone in the UI (Perspective).
For example, a Products table stores product details along with a TimeCompleted timestamp in UTC. When showing a product’s details in Perspective, I want TimeCompleted to appear in the local time zone instead of UTC.
Use the techniques involving java's ZonedDateTime that I linked.
