Is there a way to display a SVG by providing a file path like the image component where you can change the file path to change the image . I want to do the same with SVGs if possible.
Vision, or Perspective?
Vision
If you’re on a recent 8.0.X, you can directly put SVGs into Image Management and just use them directly on the image component…I’m pretty sure.
I’m on 7.9, but I plan on going to v8 soon, so I will wait until then. thanks.
