System info: Ignition 7.5.3 and Reporting module 1.5.0
I am using the Graph component (Bar chart) in the reporting module to display a time series that is a bit dense (e.g. a value each 2-3 minutes). I am using it to display durations in seconds as bars. My problem is that the Graph component does not show all values. Is there a reason for that? In addition to that the time stamps do not appear. Is there a way to show such dense data using the chart components in the reporting module?
As a comparison I used the Easy Chart in the Vision module with the renderer “XY Bar Renderer” to show the same data and that works perfectly. The chart shows very thin bars for each time stamp.
Thanks for your help.
