If we are using Ignition Edge, Hive MQ, and Ignition Engine, would we be able to get the OPC Item Path from Ignition Engine?
I am trying to display the OPC Item Path on a screen being built on Ignition Designer where the tags are stored as Memory Tags. We discussed possibly creating a database that holds the rebirth messages from these tags and then querying the database to get the OPC Item Path and some other data.
