I’ve got a swing component that I have exposed to the vision module/designer through the normal mechanisms. So, I have the designerHook and BeanInfo classes. My object is available to drag and drop into the windows of my project in designer. So far, so good.
But, I have behavior/code in that java swing object that needs to know if I am running in designer or as part of the client exposed to the user. I have combed the javadocs and searched the forum, but am not seeing a way to get what I am after. I expect this is easy and I just missed it. I am strictly working in the java space here, no python.
I did come across this bit of python code on the forum that hints at what I might need to do.
if system.util.getSystemFlags() & system.util.DESIGNER_FLAG:
I think there is a simple and proper solution that I have just missed. I have a hack in my application that relies on a singleton, but would rather learn the right way to solve this problem. Thanks in advance.
Brian
