Hi.
I have the following query into a Power Table object, which returns divide by zero error encountered message. how can it be solved?
Select MAchineID, MIN([CurrTotalGasConsumption]) as 'Inicial Consumption', MAX([CurrTotalGasConsumption]) AS 'Final Consumption',
MAX([CurrTotalGasConsumption]) - MIN([CurrTotalGasConsumption]) AS 'Gas Consumption (m3)',
MAX(TotalChargedWeight) - MIN(TotalChargedWeight) as ChargedWeight,
((MAX(TotalChargedWeight) - MIN(TotalChargedWeight))*1000) /(MAX([CurrTotalGasConsumption]) - MIN([CurrTotalGasConsumption])) as 'm3/ton'
FROM [IgnitionRuntime].[dbo].[W01_MELTING_GAS_CONSUMPTION]
WHERE
Timestamp >= '2024-03-13 07:00:00'
AND
Timestamp <= '2024-03-13 15:00:00'
group by MachineID
order by MAchineID asc
Tidied up query:
SELECT
MAchineID,
MIN([CurrTotalGasConsumption]) AS 'Inicial Consumption',
(MAX(TotalChargedWeight) - MIN(TotalChargedWeight)) * 1000)
/ (MAX([CurrTotalGasConsumption]) - MIN([CurrTotalGasConsumption])
) AS 'm3/ton'
WHERE
AND
GROUP BY MachineID
ORDER BY MAchineID asc
The only place you can have a divide by zero is in the division line,
You forgot to say which database engine you are using.
For MS SQL you can do something like this:
SELECT CASE WHEN
(MAX([CurrTotalGasConsumption]) - MIN([CurrTotalGasConsumption]) = 0
THEN NULL AS 'm3/ton'
ELSE
) AS 'm3/ton'
END
There will be something similar for other database engines.
