DNP3 Event Buffer Backfilling
I am trying to configure event buffer backfilling using DNP3 with a MicroLogix 1400 PLC.
When the device is disconnected for a minute and reconnected, no events are read from the event buffer of the PLC.
I have configured an SQLite database as the storage provider for the tag history. However, rows are not being added to the table regularly. The live tag values are being updated, as shown in the screenshot below:
I also observed the following error in the logs while performing this test:
Any assistance would be appreciated.
The existing (soon to be "legacy") DNP3 driver only receives events when using unsolicited messaging.
The new beta driver can receive events using both class-based polling and unsolicited messaging. See the beta sticky thread here if you're interested in trying it instead: New DNP3 Driver Beta
Thanks for pointing this out. I have installed the new DNP3 Driver Beta, but I am now only receiving events after a class poll. In the screenshot below, the Class 1 Poll period is set to 8 seconds, and we only see new data following a poll.
The desired behaviour is that when Ignition’s driver reconnects after it is disconnected from the PLC for some time, the events from the PLC are written to the database so that the missed events can be backfilled.
Can you get a Wireshark capture? The outstation must have the points you are interested in assigned to the class and produce events for those points. The capture will see if your configuration in Ignition needs changing or if it’s something you need to change in the outstation.
This is how it is supposed to work… if you want immediate/live updates and events you need to turn on unsolicited messaging and your outstation must support it.
Just to clarify, the device produces an event every 2 seconds. The Class 1 poll is set to be done every 10 seconds, so 5 events are produced during the 10 second interval. However, only the last event value is recorded in the database. The following screenshot from Wireshark shows the events being produced by the device every 2 seconds.
Here is a screenshot of the values that are actually recorded in the database:
This is the Wireshark capture: dnp3_capture_20231107.pcapng (2.1 MB)
I have enabled unsolicited messages in Ignition and on the device (screenshots below). However, I did not observe any unsolicited messages in the Wireshark capture.
Additionally, the Unsolicited Bit in the Wireshark capture is seen as "Not set".
The desired result is that all of the events being produced by the device are stored in the database. This is required so that missing data can be recovered in the event of a disconnection.
Did you follow the instructions on how to set up your Tag Group to preserve sequence of events / buffered data?
Yes, I believe that I did. Here is a screenshot of the Tag Group configuration:
The Queue size was set to a value greater than 1 and the Sampling Interval was set to 0 ms.
@ggross is there any tag history settings that need to be verified / set up for this to work right?
The Tag Group settings look correct. In my testing over the last couple of days, the deadband could be causing a problem with the data being stored. @Vishal_Ramjattan, can you please try setting the Deadband Mode option on the tag to Off and let me know if that changes the behavior at all.
Garth
Also, @Vishal_Ramjattan can you please check the timestamps on both the device and the Ignition Gateway to ensure they are synced to the same time source? On Interrogation, no timestamp is sent from the device and source for the timestamp is the Ignition Gateway itself. For the Class polling, if a timestamp is applied from the device then Ignition will use it. If the timestamps are out of sync we can get in a scenario where Ignition is thinking the timestamps are coming in out of order.
Garth
Hi everyone,
I was just wondering if this topic ever had a resolution? On the new DNP3 driver and Ignition 8.3, we are seeing the same behavior described here.
We have set up a DNP3 device, and Ignition is configured to perform Class 1, 2, and 3 polls every 10 seconds. In Wireshark, I can see the RTU responding with multiple timestamped changes for the same point during that interval. However, the Ignition history only seems to record one value (i.e., it’s not backfilling the history from those 10 seconds).
We also tested by disconnecting the device (physically unplugging the Ethernet cable) and restoring the connection an hour later, but still no backfilling occurred.
I believe we have set the queue/tag group settings correctly (same as the screenshot from @Vishal_Ramjattan). We also tried playing around with the Deadband mode suggested by @ggross. Finally, we confirmed the time in the RTU and Ignition are the same. :slight_smile:
Wondering if this was working in the end. Thank you!
