Docked screen is different in Designer and in Launcher
I have a docked window that I use in all my screens. However in my designer i get everything fitted like i want it but when I lanch this project some objects keep moving or are not on the same spot as they are in my designer. Is there any way to keep this from happening?
I’ve attached 2 immages of what I mean.
You need to look into the layout settings: https://docs.inductiveautomation.com/display/DOC79/Working+with+Components#WorkingwithComponents-ComponentLayout
Tentatively, you probably want to group all your buttons, then anchor that group to the bottom left. The alarm and current time windows would similarly be anchored, but to the right side.
They already are anchored that’s why this is so weird to me…
Try grouping the alarm and current time with the buttons on the right and then anchoring the group to the bottom right.
That worked! Thanks a lot!
