I’m trying to run the ignition docker image on a docker swarm (arm/v7 processors).
networks:
ignet:
external:
services:
distributor:
environment:
GATEWAY_ADMIN_PASSWORD: password
IGNITION_EDITION: full
image: ignition_configured
networks:
ignet:
ipv4_address: 172.25.1.2
The image is just the base kcollins/ignition image with the MQTT Distributor module installed and committed.
The network was created like this:
docker network create -d overlay ignet --subnet 172.25.0.0/16
The setup works in non-swarm mode (docker-compose up) and works on my amd system in both swarm and non-swarm modes. On the arm swarm, though, I get the following error:
jvm 1 | 2021/04/07 16:05:57 | I [g.ModuleManager ] [16:05:56]: Setting up modules
jvm 1 | 2021/04/07 16:05:57 | I [g.LicenseManager ] [16:05:56]: Trial time reset. Time remaining = 7199.
jvm 1 | 2021/04/07 16:05:58 | I [G.L.A.AlarmNotificationService] [16:05:58]: Remote Alarm Notification Manager initialized successfully.
jvm 1 | 2021/04/07 16:05:58 | I [c.i.i.g.o.KeyStoreManager ] [16:05:58]: Loading KeyStore at /usr/local/share/ignition/data/opcua/client/security/certificates.pfx
jvm 1 | 2021/04/07 16:06:00 | I [c.i.i.g.o.KeyStoreManager ] [16:06:00]: Loading KeyStore at /usr/local/share/ignition/data/opcua/server/security/certificates.pfx
wrapper | 2021/04/07 16:06:03 | INT trapped. Shutting down.
jvm 1 | 2021/04/07 16:06:03 | I [o.e.j.s.AbstractConnector ] [16:06:03]: Stopped ServerConnector@1d529a{HTTP/1.1,[http/1.1]}{0.0.0.0:8088}
jvm 1 | 2021/04/07 16:06:03 | I [o.e.j.s.AbstractConnector ] [16:06:03]: Stopped ServerConnector@586b9e{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
jvm 1 | 2021/04/07 16:06:03 | I [o.e.j.s.session ] [16:06:03]: node0 Stopped scavenging
jvm 1 | 2021/04/07 16:06:03 | I [IgnitionGateway ] [16:06:03]: Ignition[state=STARTING] ContextState = STOPPING
jvm 1 | 2021/04/07 16:06:03 | I [IgnitionGateway ] [16:06:03]: Ignition Gateway shutting down...
jvm 1 | 2021/04/07 16:06:03 | I [g.ModuleManager ] [16:06:03]: ModuleManager shutting down...
jvm 1 | 2021/04/07 16:06:04 | I [g.ModuleManager ] [16:06:03]: ModuleManager shut down in 305ms
jvm 1 | 2021/04/07 16:06:04 | W [C.BasicExecutionEngine ] [16:06:03]: Tried to unregister non existent unit [gatewayareanetworkconnectionmanager connection monitor].
jvm 1 | 2021/04/07 16:06:04 | E [IgnitionGateway ] [16:06:04]: Error shutting down GatewayNetworkManager.
jvm 1 | 2021/04/07 16:06:04 | java.lang.NullPointerException: null
jvm 1 | 2021/04/07 15:49:30 | at com.inductiveautomation.metro.impl.services.ServiceManagerImpl.shutdown(ServiceManagerImpl.java:133)
jvm 1 | 2021/04/07 15:49:30 | at com.inductiveautomation.metro.impl.CentralManagerImpl.shutdown(CentralManagerImpl.java:189)
jvm 1 | 2021/04/07 15:49:30 | at com.inductiveautomation.ignition.gateway.gan.GatewayAreaNetworkManagerImpl.shutdownComms(GatewayAreaNetworkManagerImpl.java:522)
jvm 1 | 2021/04/07 15:49:30 | at com.inductiveautomation.ignition.gateway.gan.GatewayAreaNetworkManagerImpl.stop(GatewayAreaNetworkManagerImpl.java:250)
jvm 1 | 2021/04/07 15:49:30 | at com.inductiveautomation.ignition.gateway.gan.GatewayAreaNetworkManagerImpl.shutdown(GatewayAreaNetworkManagerImpl.java:231)
jvm 1 | 2021/04/07 15:49:30 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.shutdownInternal(IgnitionGateway.java:1607)
jvm 1 | 2021/04/07 15:49:30 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.shutdown(IgnitionGateway.java:2294)
jvm 1 | 2021/04/07 15:49:30 | at com.inductiveautomation.ignition.gateway.web.IgnitionWebAppImpl.onDestroy(IgnitionWebAppImpl.java:130)
jvm 1 | 2021/04/07 15:49:30 | at org.apache.wicket.Application.internalDestroy(Application.java:675)
jvm 1 | 2021/04/07 15:49:30 | at org.apache.wicket.protocol.http.WebApplication.internalDestroy(WebApplication.java:700)
jvm 1 | 2021/04/07 15:49:30 | at org.apache.wicket.protocol.http.WicketFilter.destroy(WicketFilter.java:591)
jvm 1 | 2021/04/07 15:49:30 | at com.inductiveautomation.ignition.gateway.bootstrap.GatewayFilter.destroy(GatewayFilter.java:67)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.servlet.FilterHolder.destroyInstance(FilterHolder.java:164)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.servlet.FilterHolder.doStop(FilterHolder.java:148)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:93)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.servlet.ServletHandler.doStop(ServletHandler.java:238)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:180)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:201)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.server.handler.AbstractHandler.doStop(AbstractHandler.java:111)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.security.SecurityHandler.doStop(SecurityHandler.java:425)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.security.ConstraintSecurityHandler.doStop(ConstraintSecurityHandler.java:425)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.server.session.SessionHandler.doStop(SessionHandler.java:519)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.server.handler.ContextHandler.stopContext(ContextHandler.java:916)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.servlet.ServletContextHandler.stopContext(ServletContextHandler.java:367)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.webapp.WebAppContext.stopWebapp(WebAppContext.java:1450)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.webapp.WebAppContext.stopContext(WebAppContext.java:1415)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.server.handler.ContextHandler.doStop(ContextHandler.java:980)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.servlet.ServletContextHandler.doStop(ServletContextHandler.java:284)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.webapp.WebAppContext.doStop(WebAppContext.java:547)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.server.Server.doStop(Server.java:454)
jvm 1 | 2021/04/07 15:49:30 | at org.eclipse.jetty.util.thread.ShutdownThread.run(ShutdownThread.java:127)
jvm 1 | 2021/04/07 16:06:04 | I [IgnitionGateway ] [16:06:04]: Ignition Gateway shut down in 721ms
jvm 1 | 2021/04/07 16:06:04 | 16:06:04,275 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Queue flush finished successfully within timeout.
jvm 1 | 2021/04/07 16:06:04 | 16:06:04,284 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Worker thread will flush remaining events before exiting.
jvm 1 | 2021/04/07 16:06:04 | 16:06:04,286 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Queue flush finished successfully within timeout.
wrapper | 2021/04/07 16:06:05 | <-- Wrapper Stopped
Where the line wrapper | 2021/04/07 16:06:03 | INT trapped. Shutting down. seems to be the first place of divergence from normal behavior.
Any help would be greatly appreciated!
