Docking menu question
Curious,
I have to views that contain menu trees. I want to have both menus on an overview page together and toggle the larger menu with labels and icons that when collapsed will show only the icon menu. I have tried editing the docking configurations which ultimately led to me using the handle. Other than creating another header with a button that could control it, is it possible to have a small button on the larger menu that when clicked will hide it and bring up the icon menu? Is the solution a binding on custom props or should I be scripting the action with a messageHandler.
Hey Troy, you may have already resolved this, but yes you should be able to complete the actions you want with Dock Actions on component events.
The two Docked Views would be assigned to the same region, and can swap opening and closing. I would assume the smaller menu would be Pushing the content and only swaps to the large dock, whereas the larger would be Covering the content and swap back if real navigation occurs or if the go back button is pressed.
