Documentation of components
Hi All,
If you print dir(components), it will print out all the methods/attribute the component has.
Where can I find the documentation for every one of them?
Like now, I need to know what the chart.add() does and what arguments take.
Start with Ignition’s module SDK JavaDocs, and then Java’s own Swing JavaDocs.
And welcome to the underbelly of Ignition. Since it is Java under the hood, you’ll have to get familiar with Java’s object orientation – data types, subclassing/inheritance, overrides, etc. Also, if you use this stuff, and break your setup, please don’t whine about it. If it’s not in the Ignition User Manual, it ain’t supported.
