Does easy chart's tag path could use indirect tag or expression?
easy chart tag path
I want this easy chart's tag path could be dynamic. But I only can choose a certain tag. Is that possible I can use the function like indirect tag or expression to make tag path dynamic?
EasyChart is a Vision component. It cannot be used in Perspective. (You have tagged your question as Perspective.)
No, you cannot simply embed a dynamic element with curly braces.
There are two possibilities:
  • If only changing the path or limited properties of otherwise pre-configured pens, you can use Cell Update Bindings to substitute into the pens or tagPens configuration dataset properties.
  • If the number of pens is also dynamic, you can construct those configuration datasets with scripts, typically using system.dataset.toDataSet(). You need to match the column names and types those config properties expect.
