Does ignition support azure SSO?
Hi, is ignition support azure SSO idp ?
Yes. We use SAML authentication and it works. If I had the chance to go back and start over I think I'd recommend OpenID. Either way should work.
https://docs.inductiveautomation.com/display/DOC81/Configuring+Identity+Providers
https://docs.inductiveautomation.com/display/DOC81/SAML+Example
https://docs.inductiveautomation.com/display/DOC81/OpenID+Connect+1.0+Example
