Does Ignition support MQTT over websockets?
I'm setting up my own broker I want ignition to forward MQTT to.
In this other post someone says: "As stated previously, MQTT, PubNub, TCP/UDP streams, web sockets, all are possible with Ignition"
Can someone confirm if it supports sending MQTT over websockets?
Assuming you are referring to the Cirrus Link modules here:
Referring to the documentation, I don't think the CirrusLink MQTT Engine can connect to MQTT brokers over websockets.
