Does Ignition Support OPC DA to OPC UA Conversion?
We are working on a project where the client’s PLC supports only the OPC DA protocol. Does Ignition provide any built-in agent, service, or recommended solution to convert OPC DA to OPC UA so that it can connect to the Ignition Gateway?
OPC-COM module offers OPC-DA
Note that the gateway must run in Windows for the OPC DA compatibility.
If the gateway is running on a different machine, does it allow remote connection? And to connect to a remote PLC/DCS, is it necessary to have its IP address and ensure both machines are on the same network?
