Does the Internal History Provider store tags qualities?
I'm trying to get the quality stored in the interal history provide. How could I see that?
Thanks in advance!
It's stored in the Ignition Database Table Reference | Ignition User Manual sqlth_1_yyyy_mm datatable in the dataintegrity column. 192 is good!
The system.tag.queryTagHistory | Ignition User Manual function doesn't return the quality but you can call it with ignoreBadQuality = True to force it to ignore garbage. The linked page says:
ignoreBadQuality A boolean flag indicating that bad quality values should not be used in the query process. If set, any value with a "bad" quality will be completely ignored in calculations and in the result set. [optional]
Thanks! Yout actually guided me the right way.
I founded the internal historian tables and transformed those to csv, then I analized all the quality.
Thanks Transistor!
Good. Don't forget to click the "Solution" link to mark the question as solved.
