Don't reload pages when switching tab in navigation bar
Hi all
When I switch between tabs in my navigation window, the windows seems to reload every time I want to go to another window. So the page is reloading again and it takes again some time to set up. When a client launches a project, I don’t want the different windows to reload every time and want to load them just one time at start up.
Is there a way to do this?
Thanks a lot!
This is possible as an alternative navigation strategy.
You can use buttons to navigate, or if you use tabs, you must disable the default navigation mode:
Afterwards, you can react on a button click or tab switch with a script. For tab strips, you need to react on the selectedTab change. When using buttons, every button will have it’s own event.
if event.propertyName == "selectedTab":
	system.nav.openWindow("whatever/root/path/" + event.source.selectedTab)
Please also check the documentation for these functions: system.nav.openWindow - Ignition User Manual 7.9 - Ignition Documentation
  • openWindow will open a window on top, or bring it to the front if it’s already open
  • openWindowInstance will always open a new window, even if it already exists (handy for popups, where you may need to see two the same popups of different machines).
  • swap* will close the current window, and open a new one.
Note that when using the openWindow* functions for main page navigation, you lose the standard Ignition functionality of goBack, goForward, getCurrentWindow etc. As Ignition no longer can keep track of what’s currently considered the main window.
It’s far better to use swap instead of open for navigation pages. MAke sure that your pages are set to cache:
