Hi Guys,
So I am having a tag change client event scripts where I needed some delay, we used to do time.sleep() functionality before, but going through the posts in forum by @pturmel and others I understood that using Sleep() is a really bad idea. So I came across Later.py module made by Phil and started using the callLater() function.
The function and the module are working fine in components, but I see the module not responding properly when used in client event scripts, like if I define a function with some tag reads and other functionality and then the tag reads are not happening properly.
Is it something that I alone is facing or is there some compatibility issue with client event scripts, because I saw similar issues while using invokeLater function in client event scripts
