Doubt regarding message handlers
Hello,
I am working on getting the daily, weekly and monthly data reflected based on the dropdown selection. It is working and next when I launch the perspective project, by default I should get the daily data and I have written the script in message handler section -
	# Fetch the start date from the date picker component
	start_date = self.getChild("Date_Flex").getChild("StartDate_Flex").getChild("DateTimeInput").props.value
	#start_date = system.date.now()
	end_date = None
	# Fetch the selected duration type from the dropdown component
	duration_type = self.getChild("Date_Flex").getChild("StartDate_Flex").getChild("Dropdown").props.value
	duration_type = 1
	# Initialize address_durations
	address_durations = {}
	hourly_consumption_kwh = 0.0
	total_consumption_str = 0.0
	# Calculate end_date based on the selected duration_type from the dropdown
	if duration_type == 1:  # Daily
		total_consumption_str = 8400
		end_date = system.date.addDays(start_date, 1)
		hourly_consumption_kwh = float(total_consumption_str) / 24
	elif duration_type == 7:  # Weekly
		total_consumption_str = 58800
		end_date = system.date.addWeeks(start_date, 1)
		hourly_consumption_kwh = float(total_consumption_str) / 168
	elif duration_type == 30:  # Monthly
		total_consumption_str = 252000
		end_date = system.date.addMonths(start_date, 1)
		hourly_consumption_kwh = float(total_consumption_str) / 720
	# Update the end_date_picker's value based on the calculated end_date
	end_date_picker = self.getChild("Date_Flex").getChild("StartDate_Flex").getChild("DateTimeInput_0")
	end_date_picker.props.value = end_date
	# Named query with the start_date and end_date as parameters
	data = system.db.runNamedQuery("Demo", {"start_date": start_date, "end_date": end_date})
	# Check if the named query returned any rows
	if data.getRowCount() == 0:
	    print("No logs were processed during the selected period")
	else:
	    prev_state = {}
	    prev_timestamp = {}
	    for row in range(data.getRowCount()):
	        network_address = data.getValueAt(row, 'NETWORKADDRESS')
	        node_address = data.getValueAt(row, 'NODEADDRESS')
	        address = str(network_address) + "." + str(node_address)
	        timestamp = system.date.parse(data.getValueAt(row, 'TIMESTAMP'), "yyyy-MM-dd HH:mm:ss")
	        parameter = data.getValueAt(row, 'PARAMETERS')
	        if address not in prev_timestamp:
	            prev_timestamp[address] = timestamp
	            prev_state[address] = parameter
	            address_durations[address] = {"ON": 0, "OFF": 0}
	        else:
	            duration = system.date.secondsBetween(prev_timestamp[address], timestamp)
	            if prev_state[address] == 'ON':
	                address_durations[address]['ON'] += duration
	            elif prev_state[address] == 'OFF':
	                address_durations[address]['OFF'] += duration
	    # Handle duration for the last state until the end_date
	    for address in prev_state.keys():
	        if prev_state[address] == 'OFF':  # Check if the last state is OFF
	            if prev_timestamp[address] < end_date:
	                duration = system.date.secondsBetween(prev_timestamp[address], end_date)
	        elif prev_state[address] == 'ON':  # Check if the last state is ON
	    # Prepare data for XY Chart
	    duration_data_xy_chart = []
	    for address, durations in address_durations.items():
	        duration_data_xy_chart.append({
	            "address": address,
	            "ON": durations['ON']/60,
	    print(duration_data_xy_chart)
	    # Append the processed data to the XY Chart's data source
	    for entry in duration_data_xy_chart:
	        self.getChild("XYGraph_Flex").getChild("XYChart").props.dataSources.example.append({
	            "address": entry["address"],
	            "ON": entry["ON"],
 	# Calculation of Power Consumption with device (ON duration)
    # ON durations in minutes
	devices_data = sum([durations['ON'] / 60 for address, durations in address_durations.items()])
    # Calculate per minute consumption
	minute_consumption_kwh = hourly_consumption_kwh / 60
	print(minute_consumption_kwh)
	duration_data = minute_consumption_kwh * devices_data
    # Format the values for display
	total_kwh_consumed_with_unit = "{:.2f}kWh".format(duration_data)
	print(total_kwh_consumed_with_unit)
	# Calculate the difference
	difference_kwh  = total_consumption_str - duration_data
	difference_with_unit = "{:.2f}kWh".format(difference_kwh)
	print("Difference:", difference_with_unit)
	#Updating in gauge component
	gauge_day = self.getChild("FlexContainer_1").getChild("FlexContainer_0").getChild("SimpleGauge")
	gauge_week = self.getChild("FlexContainer_1").getChild("FlexContainer_0").getChild("SimpleGauge_0")
	gauge_month = self.getChild("FlexContainer_1").getChild("FlexContainer_0").getChild("SimpleGauge_1")
	# Now, depending on the duration_type, update the corresponding gauge
	    gauge_day.props.value = difference_with_unit
	    print("Daily gauge updated:", difference_with_unit)
	    gauge_week.props.value = difference_with_unit
	    print("Weekly gauge updated:", difference_with_unit)
	    gauge_month.props.value = difference_with_unit
	    print("Monthly gauge updated:", difference_with_unit)
And I am calling the message handler from the button on performed action script -
end_date = None
duration_type = self.getSibling(Dropdown).props.value
end_date_picker = self.parent.parent.getChild(StartDate_Flex).getChild(DateTimeInput_0)
payload = {start_date: start_date, duration_type: duration_type, end_date:end_date}
# Call the message handler with the parameters
system.perspective.sendMessage(Fetch DailyData, payload)
How to get the daily data as soon as the project is launched?
Can anyone please help me out with this issue?
Thanks in advance!
Tip: why have you got import datetime at the top of each script? You're not using it and you shouldn't without special reason as system.date functions will be much better.
Yes @Transistor, I am not using it and I have made use of the built in date functions available in ignition.
Edit it out of your first post. It will cause confusion.
I note that you didn't take my advice regarding the brittleness of the code as discussed in Issue while displaying value in gauge - #2 by Transistor. :thinking:
Yes I remember @Transistor
I actually wanted to try through scripting so went ahead with writing python script and working on the functionalities from the same
