Download image from an URL
Hello everyone.
We would like to download an image - snapshot from an ip camera using URL and store file on the gateway as .jpg
URL path to this camera image is like this:
http://admin:password@192.xxx.xxx.xxx:port/images/snapshot.jpg
This task(script) would be executed on the gateway event. What syntax should we use to achive this?
Thank you for your help
Start with system.net.httpClient performing a GET request.
Thank you for pointing us in the right direction. We made it work.
Here is the code if anyone should need to do the same
url = 'http://192.xxx.xxx.xxx:port/images/snapshot.jpg'
response = system.net.httpClient().get(url, timeout=20000)
image = response.getBody()
system.file.writeFile("C:/Folder/file.jpg", image)
You've formatted your code using the quotation button instead of the code formatting button. We can read it in this case but for future posts see ...
