Good afternoon,
We have a config file at 'C:\TEMP\PD_CDT\C__USERS_Configuration.txt' on certain kiosk computers.
These kiosks run Perspective screens, and one screen on that display allows a user to enter a few details that are then written to the contents of the file at 'C:\TEMP\PD_CDT\C__USERS_Configuration.txt'.
The Write Configuration button uses this script:
def runAction(self, event):
logger = system.util.getLogger('C9x_Quality_Display.ChangeLaunchedFile.Write')
try:
plant = self.getSibling("PlantDropdown").props.value
device = self.getSibling("EnterDevice").props.text
filepath = r'C:\TEMP\PD_CDT\C__USERS_Configuration.txt'
data = "https://cmcignition03.challenge-mfg.com:8043/data/perspective/client/C9x_Quality_Display/Main/%s/%s"%(plant, device)
data = data.encode('utf-8')
logger.warn(system.file.writeFile(filepath, data))
self.getSibling("PlantDropdown").props.value = ''
self.getSibling("EnterDevice").props.text = ''
logger.info('Plant/Device written to %s, %s/%s'%(self.session.props.address, plant, device))
except Exception as e:
logger.warn('%s'%(e))
The purpose of this script is to:
- Read values from dropdown and textbox
- Write these values to C:\TEMP\PD_CDT\C__USERS_Configuration.txt on the local machine
- Write '' to dropdown and textbox to rehide this button/let user know value was changed
At first, I thought that the system.file.writeFile(filepath, data) was failing silently, until I realized it is writing to the gateway's own file location.
That's not exactly what I wanted. I also don't want to use system.perspective.download() because that would just drop the file in the downloads folder, requiring the user to drag the new config file to the correct location. If that were the case, they might as well just update the file location in the config themselves manually.
Is what I am trying to do even possible? Can I write to the local computer without using Perspective's download?
