I can drag a tag to the screen and display the state or value (digital and analog). Is there a way to also display the name of the tag displayed?
Hi @eddie_johnson,
You will need to create your own template with a label linked to the name of your tag and the value linked to the desired object.
Are you using vision or perspective ?
Vision 8.1. I’ll give that a try, thanks.
In vision it's more difficult to do.
I would work with a udt definition and the drop target set to this udt, it will be easier.
