In one of Travis’ video demonstrations there is a trend display paired with a tree control that he uses to drag & drop historian tags. It’s available on the cloud marketplace but I’m on 7.6.6.
Is there a way to get this same functionality for 7.6.6? We have a lot of times when searching through data is the only way to find out what it is you want to display, so making tables & trends a-priori isn’t possible.
Are you using a tag tree in conjunction with an easy chart? Because I’m pretty sure you can do that without using anything on the marketplace. Am I understanding your problem correctly?
Yes, thank you, I would also like to use it with a table. I don’t see where the tag tree component is however. Does it exist in 7.6.6? I think that may be the problem.
