Tom done a great job of explaining some things in this topic
http://www.inductiveautomation.com/forum/viewtopic.php?f=72&t=9481
Is there a place I have not found in my searches that explains all the tags under diagnostics.
For example: I called tech support yesterday about getting the IP address of the device. Ron Lor emailed me back to use the Hostname, which I had but it was set to an Int4. I set it to a string and the whole IP address came through.
So if we knew what each tag should be set to to display correctly, and a good/easy to understand definition of what each is or is helping us to explain/diagnose/troubleshoot…
We don’t have anything like that in the user manual, but they should be pretty straightforward. All of the Duration tags are in milliseconds, here’s an example from a MLX.Requests
Average Duration - float - averade duration per request (ms)
Count - int - number of requests
Item Count - int - subscription item count (tags)
Last Duration - float - last request duration (ms)
Maximum Duration - float - max request duration since connection restart (ms)
Minimum Duration - float - min request duration since connection restart (ms)
Throughput - float - requests per second (ms)
Connection State - string - Connected/Not Connected/Connecting/etc
Device Name - string - connection name
Hostname - string - ip address
Is Connected - boolI’ve attached an image for an example (the numbers don’t all match because I didn’t refresh the Gateway section before taking the screenshot).
