Drop Configuration (action path)
Hello,
I need help and advice with using the Drop Configuration function with action set to path
Currently, with my symbols, I have a "PARAMS" which contains the "path" :
MNEMONICS : INS/TM03S1/FR02/RTE200
Then I use appropriate expression for binding :
tag("[Provider_SDA]TAGS/" + {view.params.MNEMONIC} + "/minOut.value") + " " + tag("[Provider_SDA]TAGS/" + {view.params.MNEMONIC} + "/minOut.engunit")
That is ok, but now, I'm trying to do the same with Drop Configuration. I suppose the path action in drop configuration allows us to do something similar to what we're doing now with MNEMONIC ? If yes that would be Fun.
Could you confirm ?
Actually, I don't know how to retrieve the path value that should be set automatically when Drop ?
I would be grateful if someone could help me on this subject because the documentation is not explicit enough :
https://docs.inductiveautomation.com/display/DOC81/Drop+Configuration
