Version: Ignition Perspective 8.1
Is it possible to automatically name an embedded view when using Drop Configuration to drag-and-drop a UDT onto a view? For example, if I am dropping a UDT instance with the name Pump12 I would like the Meta>name to be Pump12 when it placed into the view.
I attempted to add a parameter called name to the drogConfig, but no luck.
