Dropdown Component
Hi
Can we adjust the weight/height of the drop list arrow on a dropdown in Perspective ?
Regards
You can use shape/stroke under the style prop of the component to adjust the "size" somewhat.
  "classes": "",
  "stroke": "#D5D5D5",
  "strokeWidth": 3
Before and after
In perspective, you can just add a height prop to the dropdownOptionStyle:
Hi Daniel,
That just increase the height of the options list but not from the arrow.
At least in 8.1.25
Oh sorry, missed that part of your question.
In your stylesheet resource:
.ia_dropdown__expandIcon.material-icons.md-24 {
	width: 36px;
	height: 36px;
	stroke: black;
	stroke-width: 1;
You likely don't need all 4 of those properties, but they're to show what you can play with. Note that this will impact all dropdown components in your project.
This work like a charm. I suppose we could target specific dropdown by using the domId ?
Yes, that is how you would do it. Given a Dropdown where you've specified Dropdown.meta.domId = "myTargetDomId", you would do this:
Edit: added a space between the top level which would have the domId value and the class which the internal svg would have.
#myTargetDomId .ia_dropdown__expandIcon {
	width: 36px;
	height: 36px;
	stroke: black;
	stroke-width: 1;
I'll just point out one other option. If you want to be able to easily target more than one dropdown you can create a custom style and apply it to the dropdown component. The style can be completely empty, it's just needed for targeting purposes in the stylesheet resource.
Example would be you create a custom style called dropdown_arrow, add it as a class on the dropdown components you want to target, and then have this in your stylesheet resource:
.psc-dropdown_arrow .ia_dropdown__expandIcon {
	width: 36px;
	height: 36px;
	stroke: black;
	stroke-width: 1;
This makes it a bit easier to manage than the domId's in my opinion - but only if you expect to target more than one dropdown.
(Thanks @cmallonee for catching that just the .ia_dropdown__expandIcon class was necessary and could leave off .material-icons.md-24. Still trying to chip away at my understanding of CSS...feels a bit like latin at times :sweat_smile:)
