Dropdown font size
Hi
I'm trying to change the font size of a dropdown. I have added font under style customizer and can change it but it reset to default once I save a close the window. Is there a different way of doing it?
Vision or Perspective? Your use of "window" suggests Perspective Vision. Please edit your question and select the appropriate tag from the tag dropdown on the right.
[Error fixed.]
I'd say "style customizer" and "window" suggest vision, but I agree that it should always be tagger to make things clear.
The most common cause of this type of problem is not having 'All' selected in the Vision property editor filter. For a dropdown component, the property you want to change is 'Font'
If the Vision Property Editor itself is not visible, it can be accessed in this way:
Not sure why the other options exist tbh :roll_eyes:
It's not very intuitive. If I'm looking specifically for the font property, A to Z sorting makes sense, but selecting 'Standard' in the property editor filter is never going to occur to me. What I would like to see is a text field like we have in Perspective that actively filters or highlights properties.
Edit:
Thank you. Had to remove it from the style customizer for it to retain the settings.
