I have a dropdown list which gets its data from a one column returning select query.
I would like to add a static value to this list which does not come from the database.
How can I append my dataset with this one value?
I am trying to avoid using a gateway script…
Add the static value to your query by using a UNION
SELECT myColumn FROM myTable
UNION
SELECT "myStaticValue" as myColumn
Thanks Pat
How could I then order my dataset so the static value is the first one?
I’ve tried
ORDER BY (mycolumn = 'Static') DESC
and a few others
ORDER BY CASE WHEN mycolumn = 'Static' THEN 1 ELSE 2 END
None work for me.
Change the order of your select statements
UNION
This doesn’t seem to effect the order for me, Using MS SQL Server 2008.
Something like this:
(SELECT myColumn, 1 as myOrder
FROM myTable)
UNION
(SELECT "myStaticValue" as myColumn, 2 as myOrder)
ORDER BY myOrder ASC
