I have a dropdown used in a template that should show nothing (blank) when the 0 value is selected (which is the default), and allow users to select another value (1, or 2). This template is nested within a couple others.
However, when the dropdown is first loaded (default value of 0) it momentarily shows the <select option> prompt (acceptable), but then it shows a "0". Once I go into the template it doesn't show the zero. Then if I go back up a level and then down again it shows. Probably an initialization issue?
Even if I make the 0 row's Label a " " it still shows 0.
opening the top-level template:
going into the template:
returning from the template (without saving i.e. no changes - zero is gone):
(the dropdown is transparent over one of the buttons in a multistate button)
Dataset for the dropdown is bound to one of two datasets:
if({ALTER.pumps3},{ALTER.dataset3},{ALTER.dataset2})
dataset2 (cell update binding):
dataset3 (cell update binding):
-- in both datasets row with a value of 0 has a blank "Label"
ALTER.pumpXnumber properties are template parameters
